Is there a way using Smartripper to get a particular file(s) that will prompt closed captioning??
Thanks in advance,
hp
x(S)VCD don't (directly) support closed captioning. You can extract any subtitle tracks that might be on the DVD thou. For VCD you'd have to create permanant subtitles. For SVCD you can in theory have 4 subtitle tracks. But most DVD players don't actually support this, and the software (I-author) is nearly impossible to find, so again permanant subs are the way to go.
difference between subtitles and closed caption
By lovelove in forum SubtitleReplies: 11Last Post: 23rd Aug 2011, 18:28 -
hdmi does not support closed caption?
By impmon2 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 29th Jun 2010, 11:49 -
Closed-caption subtitles in UK
By kasfig in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2007, 12:50 -
Extracting Closed Caption and writing it back to mpeg as open caption
By CBiLL in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 03:50 -
disabling Closed Caption Texts
By pskim in forum SubtitleReplies: 2Last Post: 5th Aug 2007, 11:36
