What software do you use for CD labels and more importantly for the DVD case covers?
I just downloaded Sonic Surething labeler and I cannot get the label to print correctly on the paper to fit in the case.
What is the best software for this.
Jim
Results 1 to 9 of 9
Hi!
I just thought Id tell u that I had to change the dimensions around(ill try to find the numbers)and I use legal size paper(not the letter one, the one that is like 8something by 14something)works great! -
after trying all kinds of progs, i made my own templates and use microsoft powerpoint xp, works better than all dedicated software for me!!
Quark 5.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Paintshop pro
Thanks everyone!! I will look into these. I was able to get the Surething labeler working very nicely once I bought some 8.5X14 paper. I just need to trim of the edges. This works very well.
Jim
Pre-perforated paper for DVD case labels?
By stantheman1976 in forum Newbie / General discussionsReplies: 6Last Post: 27th May 2009, 13:40 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 16:54 -
To print labels
By mis3 in forum MediaReplies: 9Last Post: 23rd Dec 2007, 10:27 -
CD / DVD Labels - Which ones should I get?
By jcm0320 in forum MediaReplies: 4Last Post: 15th Dec 2007, 23:01 -
CD / DVD Labels
By wesmoc in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 09:42
