I read somewhere recently that you're better off capturing TV which is interlaced instead of deinterlacing it because the TV will interlace it anyway? Something along those lines...sooo...is it better to cap video deinterlaced or not? The PCTV Vision software allows me to display/capture video as 2 fields interlaced, 2 fields deinterlaced, or 1 field only.
If you capture 352x240(288)then you should select deinterlace(frame based),352-720x480(576)then you should select interlace(both A and B fields).
I always thought it depended on where you intend to play your final product.
Keep interlaced if the video is intended for the TV. (e.g. VCD, SVCD, DVD).
Deinterlace if it's intended for the PC (e.g. Divx, Xvid)
Correct me if I'm wrong.
Fozzee
Deinterlace
By leftspeaker2000 in forum DVD RippingReplies: 2Last Post: 5th Dec 2011, 06:17 -
Deinterlace for web?
By HDClown in forum Video ConversionReplies: 2Last Post: 25th Apr 2010, 22:50 -
Deinterlace?
By ZedsDead in forum Video ConversionReplies: 6Last Post: 15th Mar 2010, 00:21 -
To deinterlace or not deinterlace...
By Nilfennasion in forum MacReplies: 4Last Post: 4th Dec 2008, 01:46 -
Do I need to deinterlace? Or never deinterlace?
By rbatty11 in forum Video ConversionReplies: 12Last Post: 17th Jan 2008, 14:15
