Hi all,
My Toshy DVD is Region 2 only (UK) but I want to buy a film that is only available on R1.
But... It has RCE protection.
My original plan was to buy the film and rip it, removing the region coding... BUT... will the R.C.E. interfere with this when I burn it to DVDr?
Will the RCE transfer to my R2 player and not play the 'backed-up' disc?
Thanks for any help anyone can provide on this.
Cheers.
Comfy.
(PS) The film is 'Never Ending Story 1' which despite my age, I still think is a cool film with a smart soundtrack.![]()
nope the RCE will not carry over, you'll be fine..
as long as your television will display the ntsc dvd-r correctly on your pal television (i'm assuming) then you should be a-okay
RCE Protection Issue
By tryst1 in forum Authoring (DVD)Replies: 1Last Post: 24th Jan 2010, 10:53 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
RCE protection removal..............
By efiste2 in forum DVD RippingReplies: 12Last Post: 21st Jul 2007, 13:42 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
