I can't really find much information on these items. I was wanting to get something that would help stabalize my VHS captures. I ran across the Sima CopyMaster and the SCC Color Corrector in an old post, but no matter where I look, there isn't much information on what exactly these items do.
Could anyone please shed some light on these products?
thanks
The Copy Master is a simple device that will remove macrovision type 1,normally found on VHS tapes,I have one and it works. It's not effective on DVD. The SCC works on DVD as well as VHS because it regenerates the interval bar between frames. It will remove type 2 macrovision found on DVD disk. Neither will remove Digital copy protection,a hacked DVD player is needed for that. Digital copy protection would only be a problem if you wanted to make copies on standalone DVD recorder.
http://www.datavideo-tek.com
They have Time Base Correctors of all types and price ranges. Like the TBC-1000 Single Channel TBC which streets for around $289. Unless you want to buy another VCR with a TBC built in."Knowledge makes a man unfit to be a slave."
Frederick Douglass
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 19:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 09:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
Effectiveness of Sima CT-200 vs DataVideo TBC-1000 on CGMS etc
By orsetto in forum DVD RippingReplies: 0Last Post: 8th May 2008, 12:20 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 11:58
