loaded xvid into tmpge . used goldwave to change audio, got xvid codec watch movie on window media player but when i load it into tmpge it freezes on start. need some one with brains. it happens on all xvid movies.
What happens when you set your DirectShow priority to te highest one, and what happens when you use Virtual Dub to frameserve it to TMPGEnc?
Hello. -
it does nothing . but not really sure on what u r saying .little bit more help please.
I/m not so sure it is bad frames if it happens with "all" your XVID's.
To change Direct Show prority:
Options>Environmental Settings>VFAPI Plugin>Direct Show should be checked and have highest number under priority column."Today is only yesterdays tomorrow" -
i learnt this is a known problem with xvid codec...i had to uninstall and reinstall tmpgenc, now change all xvid movies to a different codec with virtualdub before heading to tmpgenc
adding packed bitstream to xvids
By pace508 in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2009, 17:10 -
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 16:29 -
Is this how to make Hi-Def xvids?
By Topher5000 in forum Video ConversionReplies: 4Last Post: 17th Sep 2007, 16:05 -
Choppy/Stutter playback on some Xvids
By gidxg03 in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 14:32 -
Can't get Xvids to work in VDub
By clos in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:47
