  1. Member rhegedus's Avatar
    on the jazz
    OK - I've got some home footage on two DVDs that will fit onto one DVDR without any compression. I want to join them without demuxing because the chapter points are already set.
    I've obtained the vobs and renamed them so that they are sequential:
    When I try to join them as per the guide and save the new vobs to a new folder, I get as far as:
    click OK, and then nothing. zip, squat, zilch.
    What am I doing wrong???
    Regards,
    Rob
  2. Member rhegedus's Avatar
    on the jazz
    Bump.
    Sorry, but can someone help? It would save hours of re-encoding.
    Regards,
    Rob
  3. Banned
    Feb 2003
    Columbus, Ohio
    name them VTS_01_001, VTS_01_002,VTS_01_003 etc.
  4. Member rhegedus's Avatar
    on the jazz
    Thanks - it's the most obvious thing that you most often can't see!
    Thanks again.
    Regards,
    Rob
