Is it possible to burn "Autoplay" VCD's for a standalone player.
I got one method here, but I think it only works on Computers. I use Nero.
Thanks in advance,
hp
Results 1 to 10 of 10
There is no "autoplay" provision for VCDs. It all depends on the specific player.
Some players will automatically play a VCD as soon as you put it in. Others may require you to press "Play".
Regards.
Michael Tam
w: Morsels of Evidence -
So, You cannot create(OR "RIP"
an executable file to prompt "Autoplay" like DVD's do, for a VCD??
Anyone??
hp -
All my VCDs autoplay in my stand-alone VCD player too.
All of my VCDs don't play in my stand-alone DVD player until I press "Play".
Regards.
Michael Tam
Pushing the play button IS NOT HARD, and it's really not the issue. It's trying to get the VCD creation, as close as possible to the originally ripped DVD.
hp
Force autoplay
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Jul 2009, 18:48 -
DVD autoplay
By BarnabasB in forum Authoring (DVD)Replies: 13Last Post: 5th Jun 2008, 00:42 -
re: burning a autoplay DVD
By tomcat862 in forum Authoring (DVD)Replies: 1Last Post: 21st Feb 2008, 20:36 -
Nero vision VCD autoplay
By Aliyans in forum Authoring (VCD/SVCD)Replies: 8Last Post: 31st Dec 2007, 10:54 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 15:36
