you will never solve your problem until you do two things.
one scan for bad frames in virtual dub and remove them. just because you don't BELIEVE that there aren't any bad frames does not make it so.
second you must get the
dx 50 codec which is not the same thing as the dixX 5 0 codec
get it? dx has two letters , divx has four letters.
you need the dx FIFTY codec not the divX Five Point whatever.
Results 31 to 33 of 33
where is the dx 50 codec located? i searched google and i can't seem to find it anywhere.
Did you check your cpu temperature? I also had this problem and solved it by buying a new cpu fan.
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 18:28 -
RipBot264 keeps freezing during encode
By cjbrown80 in forum Blu-ray RippingReplies: 15Last Post: 16th Feb 2010, 11:14 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 21:52 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 12:57
