Does anyone know anything about a Cendyne internal DVD+R/RW drive
? Staples has an add for this particular for $159.
http://instorespecials.staples.com/staples/listing_detail.asp?listingid=-2098576366&st...78647&offerid=
This is the link to the page. Is this a good idea? or should I consider another DVD burner?
Results 1 to 12 of 12
Sounds like a decent drive at a good price. But before you buy it, make sure it's not a rebadged NEC 1100A. If it is an NEC........DON'T BUY IT. I originally had the 1100A and it is BY FAR the worst piece of hardware that I have ever owned. It ruined many of my blank DVD-RW disks, it produced many "coasters", and froze up my computer just about everytime I used it.
Just giving you a heads up on the experience that I had. -
Originally Posted by orbital517
I also have a nec 1100A but have not had and probs with it yet, I backed up about 50 DVDs and all came out fine.. Comp never locked up once. It can with my Dell 3.06 ghz and 512 ram... -
I have the NEC 1100A drive and it has worked flawlessly for roughly 50 burns with a decent cross section of media.
Your mileage maya vary and every computer is different, so you may or may not have problem with the NEC. -
I would consider a burner that will include all formatts, both + and - media. You'll get more bang for your buck
Geronimo -
You guys are the lucky ones. I was hoping that my first DVD burner (NEC1100A) was going to be good, but it was nothing but a frustrating experience. But now with my Pioneer 105 and TDK 440n, i'm a happy camper.
+ or -
I hear that - is a lot better than + but all that is really out there or that comes with new computers is +. So, what should I get? I like that new Sony that does DVD+-R/RW CD-R/RW etc. But its expensive and external. I would like to get an external + and - so I can go from computer to computer. Any suggestions?
Thanks a bunch ! -
Orbital,Originally Posted by orbital517
Was that a typo or did you actually use a -RW disc on the NEC 1100A (which is only a +R/+RW drive)? -
+ or - doesn't matter. One thing to consider though, is bulk media that you order online, -R will be less expensive. +R bulk discs costs roughly 60%-100% more than -R bulk discs. If you plan to buy media retail, like in staples, best buy, etc, it really doesn't matter what you get.
No you seem to be the only one in this forum that consider the ND-1100A bad so I would say you're the unlucky one. And you're whining about it in every single NEC thread...Originally Posted by orbital517
BTW your 440N only has minor changes in the hardware from the ND-1100A. It has the same chipsets and PUH and is manufactured by NEC. -
My NEC1100A has been faultless since I got it, unlike my other previous 2 writers. Not a single coaster yet.
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 05:08 -
Regional Code Question - Insignia DVD player - can't play DVD I ordered..
By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 12:08 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
question about multiple titles on DVD using DVD Flick
By jimdagys in forum Newbie / General discussionsReplies: 1Last Post: 4th Mar 2008, 20:47
