i have 3 dvd's that total 4.28g and i want to put them onto 1 disk and be able to choose which movie to watch with a menu, what would be the best program for this?
Quite a lot is down to personal preference, I used to use ULead DVD MovieFactory 2, but got fed up with it constantly forcing a re-encode, no matter what settings and bitrates I used, so gave up and went over to use TMPGenc DVD Author
Its simple, very easy to use, fairly basic at the moment, but the latest version now supports motion menus, and the ability to change if you have just menus, just tracks or both
I'd say have a look at TMPgenc DVD Author, it can easily to what you want, I used it fairly recently to squeeze all 12 episodes of Fawlty Towers from 2 DVD's onto just one DVD-R, the actual authoring side of it was a doddle, plus you have a free fully functioning trial period to see if you like using it, before you have to register
But, this is just authoring software, it WON'T burn a DVD-R, it just creates the files, its upto you to burn these files using another piece of software. I use Nero, personal choice again, but there are loads to choose from
Basically, try the demos of :
TMPGenc DVD Author and Nero, see what you think
This is my 'personal' preference -
Very true steptoe, I quickly got fed up with the Ulead products as well.Originally Posted by steptoe
I tried TMPGEnc DVD Author but found it too restrictive. Easy yes, but not very creative. So I gave DVD-Lab a try and love it. So much flexibility and power. Motion menus, paged or switched chapter menus. You can demux the video and transcode the audio, and burn to DVD.
Version 1.2.1 is out, the author is continually tweaking and handling user issues. This guy cares about his customer, unlike Ulead.
For me:
I use AVI_IO to capture, I can spread the capture over my 3 HDs if space is limited.
I use VirtualDub and TMPGEnc for simple editing and Premiere for complex editing.
Then DVD-Lab for authoring and burning.
Works for me and I like the results.--
Will -
i also agree with steptoe, iuse both nero and tmpgenc dvd author and find them both great progs...........
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"?
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29 -
1GB AVI to DVD doesn't fit on DVDR?
By juggaloninjachoo in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 14:32 -
How to Fit 3 movies on 1 DVD 4.7GB and keeping high resoultion and quality?
By Virius in forum Authoring (DVD)Replies: 4Last Post: 8th Aug 2009, 16:12 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 15:00 -
edit Vob files in DVDR movies?
By SUPERIOR in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2008, 12:12
