Is there anybody who can tell me how I'm can get subtitles on my dvd. Like for an example, when I burned a movie without subtitles I would like to add a sub that I have downloaded. Is this possible? And how can I do it?
Quick summary of what you'll want to do:
A. Rip your DVD to HD
B. Make sure the subs link up with the video
C. Does your authoring app accept subs? If so, convert your subs to the format accepted by your app.
D. If your app doesn't accept subs, try muxing them with the video using WinSubMux. Then author as normal. You won't have menu control of your subs this way, but you will still be able to turn them off or on via the remote.
E. Finish authoring, DiscImaging, and Burning.
I don't want to go into it further now (kids to take care of), but you can find all the needed info for the above by checking the guides and how-to's and past posts.
Adding chinese subtitles to original DVDs
By viewpoint in forum SubtitleReplies: 4Last Post: 17th Aug 2009, 11:08 -
Best Practices for Archiving DVDs -- Keeping Mult. Audio Tracks, Subtitles
By GrayStrickland in forum DVD RippingReplies: 5Last Post: 27th Jan 2009, 10:27 -
Converting DVDs to playable PS3 format with hardcoded or external subtitles
By oldjoe911 in forum User guidesReplies: 0Last Post: 10th Sep 2008, 12:52 -
I'm a newbie and just starting out to add subtitles to DVDs
By hengler in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 04:01 -
Edit Subtitles on my dvds
By ichigo15 in forum SubtitleReplies: 9Last Post: 19th May 2007, 17:43
