Hi again,
Simple question as I cant seem to find it on this site. If I am using TMPGEnc and not using the wizard how can I split a movie to fit on to 2 VCDs. I am using Pinoys VCD template.
Thanks in adavance
1. Open TMPGEnc, close the wizard if it opens.
2. Load your video and name the output file for your first VCD.
3. Select Load and select the appropiate VCD template (NTSC/PAL) select "OK".
4. Select Settings-->Advanced tab-->Source Range. Select "Set start frame". Move the slider to approximately halfway through the video. Make a note of exactly where you place it and select "Set end frame". Select "OK", and "OK" again.
5. Select Start. TMPGEnc will make the first VCD format MPEG file.
6. Leaving the input file the same, rename the output for the second VCD.
7. Select Settings-->Advanced tab-->Source Range. Move the slider to the halfway point you noted in step 4. Select Set start frame. Move the slider to the end of your video. and select "Set end frame". Select "OK", and "OK" again.
8. Select Start. TMPGEnc will make the second VCD format MPEG file.Hello. -
Bring up the settings by clicking setting in tmpgenc
click advanced tab,
check the source range box,
double click this setting (double click the words source range)
up comes the source range screen
enter a start and end range for your range by inserting a start and end frame.
Netxtc -
Cheers. Didnt think about double-clicking the source range words
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
Tmpgenc 4.0 Xpress vs FairUse Wizard
By herzeleid in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 14:10 -
Is there a trick to Fairuse Wizard for output file size
By marioval in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 06:49 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:28 -
Emptying File Transfer Wizard Folder Memory?
By ahhaa in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:47
