hello>>
i was just wondering what all theses DVD formats mean e.g DVD+RW, etc..>>
what format do normal DVD's that you buy from the shops use? Are they also each different?
Also does that mean if I buy a DVD Writer I have to chose the same media type that the original cd used when burning to a blank cd??
thanx>>
The formats, either +r/rw or -r/rw, are only for recordable DVDs. The rw on the end just means the disk is rewritable. Store bought DVDs don't follow either format. They aren't burned, but rather pressed on to the disk. As for which format you should use, the choice is yours. Personally, I use Pioneer drives and -r media exclusively. However, you may want to buy ine of the dual format drives. This way you can use either format, and can shop around for the best deals.
Sometimes, ya just gotta.....umm, what's the word........FART??? -
STOP! This is the 2nd or 3rd time this week we've had to rehash this.
Jaded hopefully this will help provide some answers.
https://www.videohelp.com/forum/viewtopic.php?t=152616 -
Originally Posted by letgoofmyears
I know there are newer drives out that are both -/+ meaning they support any dvd r format +/- but if your drive is only a - you cant use + and if its only a + you cant use -
what type of dvd burner do you have???
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
avchd to dvd with vegas --so confused--
By baross in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Aug 2010, 22:48 -
Confused about all the different video formats
By jacatone in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2010, 07:50 -
Confused with video formats and Handbrake
By saurio in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2009, 15:58 -
new...confused..how to capture from dvd to dv
By ldubb619 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2007, 15:22
