This may sound a bit like a newbie question although I'm using ffmpegX for quite some time. Anyway this is the first time I have to join 2 Files. My problem is the following:
- I have 2 mpg-files that I want to join into one.
- In ffmpegX it seems to be very simple - So I'm selecting the two files under the tools section and
- click on "join"
- ffmpegX says that it finished the files, although I haven't declared any destination where to save the new file
- thus there is no joined file
So where is the so called "finished file" ?!?
I also tried it with a destination in the "save as" input field but I get the same result: "Finished" but no file.
Thanks for your help
Results 1 to 11 of 11
AnonymousGuest
Sometimes ffmpegX can't join or work with some files... I don't know what causes this, but I've been having trouble with it as well. But when you want to join 2 files... it will result in 1 file in the same dir as the first selected file. So if it isn't there, than it hasn't worked. The joining does take some time (1-2 maybe 3 minutes) so if it says Finished immediatly you can be certain that it failed
How to make it work.. beats me.. hopefully major knows an answer to this 1
" Military intelligence is a contradiction in term."
- Groucho Marx
AnonymousGuest
Hmm - you were right major4. I had a whitespace in one of the folder names. Should've found that out by myself. Anyway your reply helped me a lot - thanks!
AnonymousGuest
Special characters like ()'s in the filename seem to break the join too. I had problems joining until I took out the ()'s in the filenames.
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
join MZ TS files together
By dude905 in forum Blu-ray RippingReplies: 8Last Post: 3rd Apr 2011, 22:48 -
How can I join 2 sup files?
By EC in forum SubtitleReplies: 3Last Post: 25th Mar 2010, 12:51 -
2 movie files, 2 sub files. Need to join them into one
By andre477 in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 22:03 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
