Hi folks
I recently encountered a problem with DVD2SVCD. Iīm using it with the change CD plugin and the AutoFit plugin to convert an avi into SVCD. Everything went all right but when I checked the output I realised that there is only one output file, where should be two. CCE tells me that there are two but there arenīt. Extracting the mpeg and watching I noticed that at a certain point the picture stops and the sound moves on. The picture is all over black and on the top there is an red text which says: "AVI Source: failed to decompress frame 41479 (error 100)". I did this twice with the same result. The avi works well. At the second time first I ran the avi throught VDub (video and audio direct stream copy). Ah, its a pitty, Iīve forgotten to check the "donīt delete any file" box. Does anyone know where the deleted files are?
What can I do? Please help!
Here is what the DVD2SVCD-log says:
WNASPI32.DLL 4.6.0.1021
- 21.06.2003 01:38:53
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.1.2 build 1
Initializing
Initializing finished.
- 21.06.2003 01:38:59
- Free on drive D: 6227.91 mb
- AUDIO Extraction
Audio extraction finished.
- 21.06.2003 01:39:50
- Free on drive D: 6150.84 mb
- AUDIO conversion
Converting MP2 to WAV. Filename: D:\Filme\recent\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"C:\Programme\Zubehoer\Video_CD\DVD2SVCD\MADPlay\m adplay.exe" --quiet --output=wave:"D:\Filme\recent\Encoded_audio_1.mp2.w av" "D:\Filme\recent\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of D:\Filme\recent\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: D:\Filme\recent\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Programme\Zubehoer\Video_CD\DVD2SVCD\BeSweet\B eSweet.exe" -core( -input "D:\Filme\recent\Encoded_audio_1.mp2.wav" -output "D:\Filme\recent\Encoded_audio_1.mp2" -logfile "D:\Filme\recent\Encoded_audio_1.log" ) -ota( -g max ) -shibatch( --rate 48000 ) -2lame( -e -b 192 -m s )
Audio conversion of D:\Filme\recent\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 21.06.2003 01:54:53
- Free on drive D: 5183.20 mb
- Converting Pictures
Converting: C:\Programme\Zubehoer\Video_CD\DVD2SVCD\DefaultCha ngeCD.bmp
Finished converting pictures
- 21.06.2003 01:55:13
- Free on drive D: 5182.39 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 1666479976
AudioSectors: 123297496
VideoPAPO: 23904720
ScanOffsetBytes: 151915
SeqAligningBytes: 9655055
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 300.00
PureMPEGStream: 1509470781.87
Seconds: 5068.84
CalcMPEGStream: 1509470781.87
Frames: 126596
CDSize: 800.00
Number of CDs: 2
Cut point 795.00
Variable Settings:
Frames: 126596
Anti Noise Filter: Off
Passes: 3
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2230
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\Zubehoer\Video_CD\DVD2SVCD \MPEG2Dec\mpeg2dec.dll")
AVISource("E:\Filme\sonstige\GW\GINAWI~2.AVI",Fals e)
ConvertToYUY2()
# -= AviSynth script by FitCD v1.1.2 =-
BicubicResize(448,560,0,0.6,0,5,512,390)
AddBorders(16,8,16,8)
ResampleAudio(44100)
----AVS End----
Closing program
CCE Max Speed: 1.830
Video Encoding finished.
- 21.06.2003 05:17:30
- Free on drive D: 4540.89 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Programme\Zubehoer\Video_CD\DVD2SVCD\bbMPEG\def ault.ini
- 21.06.2003 05:17:36
Executing RunbbMPEG. Commandline:
"C:\Programme\Zubehoer\Video_CD\DVD2SVCD\bbMPEG\Ru nbbMPEG.exe" "D:\Filme\recent\ChangeCDPicture.bmp.mpg"
- 21.06.2003 05:17:48
- Free on drive D: 4540.85 mb
- 21.06.2003 05:17:54
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 795 mb
"C:\Programme\Zubehoer\Video_CD\DVD2SVCD\bbMPEG\Ru nbbMPEG.exe" "D:\Filme\recent\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
- 21.06.2003 05:22:59
- Free on drive D: 3790.52 mb
- Determining length of audio
Analyzing: D:\Filme\recent\bbMPEG_Muxed_File00.mpg
5060.592 seconds D:\Filme\recent\bbMPEG_Muxed_File00.mpg
Analyzing finished.
- 21.06.2003 05:24:23
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 28
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"C:\PROGRA~1\Zubehoer\Video_CD\DVD2SVCD\D2SCCD\d2s ccd.exe" --verbose --cue-file="D:\Filme\recent\CD_Image_File_CD1.cue" --bin-file="D:\Filme\recent\CD_Image_File_CD1.bin" "D:\Filme\recent\VCDXBU~1.XML"
CD-Image creation finished.
- 21.06.2003 05:27:38
- Free on drive D: 3780.07 mb
- SVCD Creation finished!
Hope you can help me
diver
Results 1 to 1 of 1
Welcome - to the real world
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 18:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 10:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 01:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 17:08
