I'm trying to play some ps2 backups I have using the flip top cover and swap discs. None of them seem to play, DVD or CD. I think that I'm burning them right, I use the Decryptor to make an ISO file the burn the image with Nero. MY ps2 was one of the first ones released and I have a DVD+RW drive, is it a compatiblity issue? I don't know if I'm making the backups incorrectly or if I need a new ps2. Any help would be greatly appreicated. Thanks in advance
it may be that your ps2 cannot read dvd+r discs.. a good way to find out is to put the disc in through the tray and try booting it like an original game.. if it gives you a disc read error then you know your ps2 cant read dvd+r/w discs.. if it gives you the red screen of death, atleast you know that it can read them because it knows you're trying to play a copy, which means you're doing something wrong..
you may also want to try higher quality media. (verbatim)
the method i use to backup my ps2 discs is to create a global image (.gi) through prassi primo dvd (aka recordnowmax) and then burn the image.. it has never failed me..
i have a v7 ps2, which will read dvd-r, dvd+r, & dvd-rw.. i'm not sure about dvd+rw as i have not tried it yet.. -
Originally Posted by jeex
I have tryed to play burned DVD+R disc (DVDs) in my PS2 but they don't work...try different media..theres my two cents -
What version ps2 do you have
does it have 8 or 10 screws on the bottom
there are 7 different us version and mainly 5-7 will play DVD+R's
Most of the time version 1-4 wont play +r's but there are some exceptions
All PS2's will play dvd-r's as long as the laser is in good shape and you use good media
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 04:35 -
Playing PS3/360/PS2 games on PC.
By reko_t in forum Capturing and VCRReplies: 4Last Post: 30th Nov 2010, 23:50 -
Playing ripped dvd in ps2
By hrgrosskopf in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:04 -
Legal question regarding backups
By ChaunceyK in forum Newbie / General discussionsReplies: 30Last Post: 4th Oct 2007, 08:00 -
The Importance of Backups
By Soopafresh in forum ComputerReplies: 11Last Post: 9th Sep 2007, 17:31
