I have done extensive research here and elsewhere but was not able to find the solution to the following.
A couple of times I came across movies that were incorrectly encoded to SVCD MPG without letterboxing. The image is 480x480 (as it's supposed to be) but instead of having the black bands, it fills 100% of the frame space. The result is horizontally stretched and I don't know what to use to resize it. TMPGEnc accepts any available format except MPEG-2.
Suggestions ? Thanks!
Simon
TMPGEnc does accept MPEG-2. That is what the "MPG" in TMPGEnc means. Did your trial period expire? If so, try to register it. If you are a little strapped for the moment, maybe you can load it into Virtaul Dub MPEG-2 mod and frameserve it to TMPGEnc.
Hello. -
You need the mpeg2 plug-in for TMPGEnc, it's in the Tools section!
"Art is making something out of nothing and selling it." - Frank Zappa -
Tommyknocker, the VDub method worked. Thanks.
ZippyP, I don't see anything in the Tools to resize, where exactly is that ? -
You might not have to re-encode at all...
Try opening the file up in DVDPatcher or ReStream. They both have functions that set the Display Aspect Ratio flag. This isn't what most people here use them for, but the feature is there nonetheless and you might as well try it if you need it.
HTH,
Scott -
For anyone having trouble importing mpeg2 files into TMPGEnc, here's the mpeg2 plug-in: https://www.videohelp.com/tools?tool=TMPGEnc%20MPEG2%20Plugin#comments
Yeah, I didn't notice the subsequent post.
Nonetheless, I know even if I successfully re-encoded and then later found that I didn't have to, I might want to start from scratch again so I could retain the highest quality.
That and it's useful information to know.
Or I'll just shut up.
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 12:02 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
