hi....
i downloaded a movie that came in two parts already.... but now i want to put it to a vcd to play on my dvd player... but is there any way i can do this without splitting the movie into 4 parts now??????
i'm using tmpg and virtual dub to extract the audio... and vcdeasy to burn.....
can someone help me out ... or maybe give me some likns on where i can find any info on this ???
thanks
The file size of your encoded MPEG depends only on the bitrate and souce runtime. Resolution, size of your souce video, etc. have no effect on MEPG size.
If you encode to the VCD standard 1min=10MB. So a 80min movie would be 800MB (ie. just fill an 80min CDR
So the question is how long is your video? If you so choose you can make an xVCD at a non-standard resolution to put more video on each CDR (use a bitrate calculator, there are several under the Tools section to the left, to determine the bitrate for a given runtime to completely fill a CDR). -
sorry i'm new to this.... i calculated that 55min of video... would be 1875kb/sec... with 96kbit/sec audio .... but how do i adjust this in tmpg????? its greyed out when i want to change it...
you said you were going to make a vcd. vcd has a standard resolution. so just load first file in tmpgenc and choose a vcd template and convert. tmpg will tell you if it will fit on one disk or not. to answer you other question load your template then go to tmpg folder called extras and load the unlock template. you do not need to do this if you are just making a plain vcd.
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
