I am trying out DVDLab and have figured out everything except how to include my DVD compliant mpeg short clips as thumbnails. I want to use these clips on the main menu, as thumbnails for my titles. I allready know how to place a video clip as the Motion Menu background, It was just a matter of dragging and dropping into the open menu. According to this guide it says the same thing.
http://www.mediachance.com/dvdlab/tutorial/motionmenu.html
It says to drag my clip in to the menu, but when I do that it replaces my motion background.
There has to be a way to do this. I am using the trial version, and would like to purchase this , but need this to work.
My goal is to create a Motion Menu background, and on the menu a couple of thumbnails with motion.
Ulead DVD Workshop works real good for this, except I dont want to spend 300 dollars, for something I know DVDlab can do for so much cheaper.
Thanks in advance
Sorry,
You can't just drag and drop motion thumbnails in DVD-Lab. But it's not too hard to make them.
I made you a guide....
https://www.videohelp.com/forum/userguides/164477.php
Thanks for the guide. It would be so easy to to create a frame, then drop a clip into the frame.
Vizcaya -
Would be nice. I believe in that case the authoring program would have to mpeg encode the menu. I'm not thinkin Oscar is going to do that with dvd-lab.
That type of feature makes sense for TEMPGEnc. I believe there is authoring sw from them.
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 12:14 -
m2ts thumbnails
By Driber in forum Video ConversionReplies: 1Last Post: 26th Sep 2010, 08:28 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 17:47 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
Problem with DVDlab and 16:9 motion menus
By sektionschef in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 06:11
