I was wondering if I was making an XVCD and the AVI I have has 480x360, what should I do? I want to achieve the highest quality possible. Should I make the size 480x480 or just leave it at 480x360? If I leave it at that, what would happen on the TV? Would it be stretched?
480x360 is NOT a safe NTSC resolution, I doubt it would play on your TV at all. You should re-encode to a NTSC safe resolution. In theory this can be anything that's divisible by 16, however to be safe stick to:
720/704/480/352 x 480/240
Due to the way NTSC interlaced TVs work I would only use horizontal resolutions of 480 (both fields) or 240 (one field). -
Ok. Ah! I just found out through VDub that my files were corrupted. How do I make them normal?
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 11:57 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 08:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57
