Ok, i am slowly learning, but i am now getting a floating point error. I know what frame it occurs on, and have run divfix and virtual dub on it, but i guess not correctly as it stil;l freezes up at the same point.
Any ideas what to do?
Results 1 to 11 of 11
Did you select Video-->Scan video stream for errors in Virtual Dub?
Hello. -
i do that, then i go to compresion under video and select codec 5.0.5 and then i save it as an avi.. I figure i gotta be missing something
Scott -
Let's take a step back. What is the source file?
Hello. -
When you say you ran Virtual Dub om it, do you mean you selected Video-->Scan video stream for errors?
Hello. -
yep. and it said it found some errors.. i think it was 7 frames that were unreadable, and 140 that were readable but had problems.
Scott -
And you know how to delete the bad frames and save the video to a new file name?
Hello. -
if it doesn't do it automatically, then i gues i haven;'t been deleting the bad frames.. how do you do that...
Also will deleting the bad frames start to cause a lag in the audio?
Scott -
It seems that i was able to process the video, but there now seems to be an audio lag. It starts out ok, but within a few minutes the audio and video are seriously out of sinc...
I gotta say there is more to this than i had expected
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 12:42 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47
