every time i try to encode final destination 2 from an avie to mpg TMPGEnc freezes up. if I try the same set up up with any other movie it will encode. it will not encode this move. any suggestions. is it because the video is xvid? ive done a lot of vcds but this one will not encode it will lock every time. if i close the program and open it right back up and try a differn't movie it will work?
Did you scan and remove bad frames with Virtualdub? Check the Guides section for How To.
Computer Keeps Freezing
By Squid_uk in forum Newbie / General discussionsReplies: 14Last Post: 11th May 2008, 08:43 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 04:40 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 18:43 -
AVI comes upsidedown using TPMGenc 4.0 XPress for editing
By rominho in forum Newbie / General discussionsReplies: 4Last Post: 17th Jun 2007, 20:38 -
By rominho in forum EditingReplies: 0Last Post: 14th Jun 2007, 10:09
