I have an ATI AIW 128, running on a PII 400, 256 megs of ram.
I have ATI's multimedia center setup so that it captures into the the exact right size and bitrate for a vcd (352x240, 11500 kbps), then just merge all the files togeater with the "MPEG Tools" in TQMPEG (I found that if you just select "VCD" in the dropdown of the merge window, and add all of your mpeg clips, tq will do a VERY quick job of making the mpeg ready for burning. It takes about 10 minutes to do the merge/convert an entire Dr Who episode if I record directly into a 352x240 mpeg at 11500 kbps. But I digress. basically I"m saying yes I know what I'm doing, yes the computer is turned on
Anway no matter what I try, the sound is very faint when I put it in my stand alone player (or on my computer), and I have to crank the volume.
Any suggestions?
Thanks,
Azephrahel
Try capturing the audio through your soundcard instead of the audio inputs on the AIW. You'll need an RCA to 1/8" adapter if you don't already have one lying around.
I'm not sure why it happens, but I've had the same problem with my older AIW Pro.
JJ
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
Faint vertical line on the left side of LCD... normal?
By siratfus in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2008, 03:15 -
faint audio on captured .avi file
By coastie in forum AudioReplies: 1Last Post: 27th May 2008, 05:54 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Why New Music Doesn't Sound As Good As It Did
By MeDiCo_BrUjO in forum Off topicReplies: 5Last Post: 12th Jul 2007, 17:44
