Results 1 to 9 of 9
    Feb 2003
    florida
    tring to convert movie to dvd format, audio is mp3 and video is ms-mpeg4 v3 everytime i pop it in to be converted i get a error, have any ideas????????????????
    universe
    that sounds like windows media 9 format
    Feb 2003
    florida
    any suggestions???? im using your typical tools to convert, lifted the audio tried everything i know of
    Apr 2002
    The State of Frustration
    How are you trying to convert it?
    Hello.
    Feb 2003
    florida
    im using tmpgenc, i also coverted the audio to a wav file, tried letting, ulead dvd factory convert the file also.no luck either way
    Apr 2002
    What error are you getting, is your Direct Show priority set to be the highest file reader, and are all your codecs loaded?
    Hello.
    universe
    you need to get the windows media 9 codec to convert it. once you have this you can use stoik video convertor at stoik.com to convert to an avi then use in tmpgenc. MS= (MicroSoft) m4/3
    Feb 2003
    florida
    i just get that tmpgenc has excuted and error, i havent tried the winodws 9 codec yet
    Feb 2003
    florida
    thank you secretagent i just used stoik and chnaged the format that worked fine, great program!!!!
