  1. Using TMPgenc, I created a video file called movie.m2v and an audio file called movie.mp2. In order to use Ulead DVD Workshop, I have to convert the audio mp2 file to mpa. People here kept saying renaming the mp2 to mpa. I tried to rename the file, but I still get the .mp2 extention...i.e. "move.mpa.mp2" ......Please help!
    A Yellow Submarine
    on your explorer window you have to have it set that you can view the extentions. Go to view-->Details. Or, I think if you right click on the file and select properties you can name it that way.
  3. Originally Posted by Donny661
    I went into "folder options" and unchecked "hide extensions for known file types" and it worked. Thanks!
