    Jul 2002
    Toronto Canada
    ok...i try to convert a vcd mpeg1 to mpeg2 for a dvd ...i dont want to make a dvd/vcd. well i try to convert it and when i do it allways goes out of synch and the file is now over a gig and it was 200 mb before...but in tmpgenc it says i would be able to fit over 200 minutes on one disc. how is this possible and how do i make the audio synched please help
  2. Member Dhruv's Avatar
    Aug 2001
    Australia
    Try extracting the audio from the mpeg1 into a .wav file with VirtualDub, and then converting that and the video file to a mpeg2. Might fix the audio sync problems, otherwise just try some guides from this site.
    As for the size, what setttings are you using for Tmpgenc?
    I only dream in black & white...
    MSN: paschendale@gmail.com
    Jul 2002
    Toronto Canada
    i dont really know...im a noobie when it comes to that stuff....all i know is that i want to fit around 200 minutes on 1 disc...what settings would i need?
  4. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Well if you are working with a high enough quality source then I would say use half D1 resolution for your mpeg-2 encoding. This means that instead of 720x480/576 (NTSC/PAL) you would use 352x480/576 (NTSC/PAL). Even using the highest quality setting for MP2 sound (or even if using AC-3 sound) you should still be able to fit 200 minutes per DVD. You will have to play around with the bitrate setting to find what works for you but it seems that most people use a setting of at least 2400kbps upto about 3500kbps for their bitrate settings. The few times I've tried half D1 resolutions I've done VBR with an average of 3000kbps and a peak of 3500kbps. This created a pleasing image to my eye while allowing more than 120 minutes though it could be that those settings might be too high to fit a full 200 minutes. I haven't done half D1 enough to become familiar with what bitrate to use for getting "exactly" X number of minutes per DVD disc.
    I've never tried to upconvert VCD (which is usually 352x240 NTSC or 352x288 PAL) so I don't know how well the image will scale up in terms of quality.
    - John "FulciLives" Coleman
    Jul 2002
    Toronto Canada
    i did all of that and...it still goes out of synch about 20 mins into the show
  6. Member Dhruv's Avatar
    Aug 2001
    Australia
    Does the sound gradually go out of sync, or does it just suddenly go faster/slower after 20 mins?
    This may sound stupid, but it happens to me so often when I have audio sync problems - make sure your TV/DVD Player are set on the same setting of the DVD (eg. PAL/NTSC).
    If that fails, try it on a computer or another DVD player; that way you'll know whether it could be compatibility problems with the media you're using and your DVD player.
    If you still have no luck, then try my guide here if the audio suddenly goes out of sync, or try this one if it goes out of sync gradually.
    Best of luck,
    Jul 2002
    Toronto Canada
    hi, whenevr i capture a 23 minuet tv show with ati capturing program...it ends up being 28 mins...then after i capture the sound to a .wav the sound is only 18 mins and when i try watching it the sound gradualy goes out og synch up to like 30 seconds off..i have had this capture card for about a year and i still cant capture anything proper...does anyone know how to fix it?
