When I rip a DVD using the Backup option and test the ripped VIDEO_TS folder I get a message asking if I want to change the region. When I select yes or no it still won't play. What gives.
I did go into the settings and check the box to remove regions and I still get a message. Is this a new encryption process to stop copying?
Switch to DVD Decrypter 316 and you will longer have the problem.
I have never had a problem with any DVD with SmartRipper in over 300 rips. Also I just used the default settings. Did you mess with the default settings?
The only times I ran into an error with SmartRipper it always turned out to be a disc problem and then in most cases a simple cleaning fixed the error.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57
