Hey Guys,
I was doing some thinking. I have some PAL cassettes lying around and I was wondering, if I got a Capture card (something cheap like AIW VE or WinTV). Would it be possible to read in the cassette from a normal US VCR and then capture in NTSC?
Thanks.
You must have a VCR that will play PAL tapes. They will not even play on a US NSTC VCR. If you have a VCR that plays PAL and outputs the signal as PAL you must capture as a PAL signal. Then you can convert it to NTSC using various programs (Mpeg encoders, etc). If you have a multiformat VCR that plays PAL and will convert the signal to NTSC you will be okay to capture as NTSC. They start in price at around $400 (real cheep ones) and go up from there.
Russ
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 04:36 -
NTSC Camcorder feed thru capture from PAL
By INFRATOM in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 29th May 2009, 02:17 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 08:25
