  1. hi folks,
    i tried to convert the newest "monsters inc."-trailer from quicktime to avi.
    so i copied the "qtreader"-plugin into my tmpgenc-directory. but the program crashes any time i try to load a .mov-file (tmpgenc beta 1.2j). the qtreader is a download-link from this site...
    does anyone know what the problem is?
    then i tried to convert .mov 2 .avi by the "mov2avi"-commandline-tool... but then when i try to converty the .avi 2 .mpg by tmpgenc theres only a blank white screen with black up and above....
    pls HELP!!!
    i want to watch this fabulous trailer on my standalone-player.......
    thx
  2. I'm not sure about .mov2avi.
    But I used RAD for Monsters to go to AVI.
    Some .mov files may not be converted in TMPGENC.
    Search .mov to .avi and a few reasons for the problem will be found. Most likely you have QT 5 loaded?
  3. yes i have qt5 - but only the "lite"-version not the "pro"...
  4. where do i find the tool "RAD for Monsters" youŽre talkinŽabou?
    i searched for it but found it nowhere...
  5. No, I used RAD to convert Monsters. http://vcdhelp.com/mov2avi.htm
    <font size=-1>[ This Message was edited by: moog on 2001-09-25 13:54:09 ]</font>
  6. LOL
    ok, i was a little bit stupid
    thx
    iŽll try it tomorrow..
