can anyone help me to convert vob files to mpeg2
regards joe
You use Virtual Dub MPEG-2 mod to frameserve your VOB to TMPGEnc, then have TMPGEnc convert it to MPEG-2.
Hello. -
This thread might help:
https://www.videohelp.com/forum/viewtopic.php?t=162460&highlight= -
best way ive found with superb quality, is once youve got yer vob files on yer comp, (using dvddecrypter, i use that no probs)
is to the use dvd2avi, but dont worry about the name, you isnt actaully gonna do an avi, but the prog can save a "project" that tmpgenc understands, there is a guide on this site that tells you how, and i use that method all the time
its full proof, never had a prob, i have never "frame served" anything no need to (sorry tommy)
https://www.videohelp.com/sefy/?id=ClassicalGuide.html
when it says smartripper i dont use that, dvddecrypter is better, its easier and knows where the main film vobs are and saves these to hardrive
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 12:22 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
Can't encode VOB to MPEG-2
By radellaf in forum ffmpegX general discussionReplies: 3Last Post: 11th Jun 2008, 19:08 -
Vob to mpeg-2 question
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2008, 23:16
