  1. Ok I searched a lot of threads... I was converting avi to mpeg2 audio and video and after three tries and nine hours lost I thought I should ask for help.
    I have audio loss after aprox. 6 seconds I am at a loss here any help would be great.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    If you give your conversion method then it's easier to give suggestions, the more details the better.
    Some suggestions though:
    Scan and remove bad frames using Virtualdub, look in the guides section.
    Extract a wav file (after scanning) and use that as your audio source, I prefer Goldwave.
  3. Thank you ! There might be more problems then what its worth to convert these from avi to mpeg. They have no problem converting to vcd for some reason........ ? These file sources were hand me downs from a web source. video Q is good even in vcd so maybe I should just let it go... and wait il the box set comes out on dvd. But you know what they say the Matrix has you ...... I can live til nov dvd release with vcd quality
