Not sure if this should go in here or Authoring really but here goes.
I am currently having a problem putting one of my SVCD movie sets onto DVDR. I have done about 10 so far with no problems but this one is giving me problems and I hope someoen can help please.
What I normally use is DVD-Lab and drag the Mpeg files in and run Audio Transcode and it imports ok. However on this set I'm trying to do 2 of the files work ok but the third one wheneve I click on 'Transcode Now' it says 'Cause:Can't access the file' '...if such file exist check it is not in use'
I have made sure the file isn't in use or anything basic like that, so what I tried was using TMPGenc joining the three sets together and then tried it again but it did the same thing.
Does anyone know what is causing this or is they any external apps I can run on the file to fix the problem ????
Results 1 to 1 of 1
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
