Hi guys,
Is it possible to burm multiple movies on DVDr?
Is so could someone point me to a guide?
Thanks in advance.
one way is to convert tow movies to CVD nonstandard 48mhz audio and then burn them with movie factory 2.
The easiest way i've ever heard (and hence the one I use).
Load both of your movies into your DVD authoring software.
Select write to disk instead of burning a DVD or writing an image.
Then use something like DVD2One to shrink the VIDEO_TS folder to a size that'll fit on the blank DVD.
There is loss of quality - something has got to give somewhere - I usually only put two onto a DVD but have at times managed three. -
Yes, nearly every authoring program allows you to add as many titlesets as you have space for. If you mean backing up two DVDs to one DVDR, then yes. But the process can get more involved.
There are authoring guides to the left. -
Thanks for replys guys.
Can anyone recommend DVD authoring software?
Whats the best & easiest to use? -
"Recommend" is a bad word, "Suggest" is a better one
I can do this with TMPGenc author really easy. You can add your files as tracks or as subtracks.
It is possible to add 99 files as subtracks, but they have to be same framesize and GOP. I don't know if they have to be also same type (all progressive or all interlace or all mpeg 2 or all mpeg 1). But you can add 255 files as tracks with no problem and restriction. So, I suggest you TMPGenc Author.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 18:18 -
Editing to match tapes from mulitple cameras of the same event
By SCDVD in forum EditingReplies: 5Last Post: 17th Mar 2008, 19:06 -
edit Vob files in DVDR movies?
By SUPERIOR in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2008, 12:12 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28
