iF I capture into my computer the sat night fight in mpeg 2 format, how then can i go back and edit out scenes i dont want? Thanks
Look at the guides to the right for Tmpeg. It will allow you to cut out the commercials.
Ummm... the guides on on the left of the page.
You can use VirtualDub to cut out unwanted scenes. -
The feature you need is the "clip editing" in TPMGEnc. Load the captued MPEG2 into TPMGEnc. Load the template (or configure the settings) you want. then click on "Settings" (bottom right). click on "Advanced" and then "Source Range". Clip editing is in the bottom left. Select the bits you want toi get rid of (or keep) and then choose the "clip edit" option. It is fairly intuitive.
If you find problems scrolling forwards or (particularly) backwards to set your areas for cutting/keeping, I would recommend you run the original mpeg2 through dvd2avi first, then use the resulting .d2v and .wav as your video and audio sources in TMPGEnc instead of the original MPEG2.
You an do similar with Virtualdub, but you need one of the modified MPEG2-capable variants. This approach is more complicated so I would tend to recommend the above.
Good Luck
Mpeg-2 editing confusion...
By amtt in forum EditingReplies: 41Last Post: 3rd Mar 2011, 17:47 -
editing program - sd mpeg
By devdev in forum EditingReplies: 5Last Post: 21st Oct 2010, 12:53 -
MPEG editing
By mkr10001 in forum Video ConversionReplies: 6Last Post: 15th May 2010, 23:54 -
Keyframes and MPEG-2 editing
By ffooky in forum MacReplies: 8Last Post: 5th Feb 2009, 04:17 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 04:52
