i'm gonna have to buy one so i might as well bend over. please help me out on choosing the most affordable tbc. i rather spend the money once and get one that works rather than buy an el cheapo and waste my money. however, cheap is good if it works. i've heard a lot about the tbc-1000. thanks to all who choose to help.
I have a TBC-1000 and a TBC-4000. I got a little too excited on EBay and ended up winning both! The TBC-4000 is nice because it has video proc controls, but otherwise the TBC-1000 provides the same quality. Both units soften up my SVHS tapes a little, but I can compensate for that by setting my VCR to edit mode. If you are putting two hours on a DVD, then this filtering may actually help the encoding process. Using the TBC has eliminated the video/audio skew problems that I was experiencing. Both units are built very well, prosumer quality.
thanks a bunch for the fast reply would i be be imposing to ask for the price you paid(or anybody) for the tbc-1000? any recommendations for the best place to purchase one(online) would be much appreciated. thanks everybody!
I got the TBC-1000 used via Ebay for $215 after shipping. Most places I have seen charge around $279 for a new unit.
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 20:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
