hopefully someone here can respond quickly to this question. I'm trying to use IDVD on my powerbook
Ok i have a movie in mpeg2 format. I used QTpro to encode it to a mov file. However upon playing it back it looses it sound. If i encode the file with QTpro to an avi will it do the same? What format should I use that will enable me to keep both my vidoe and sound in place when i make the dvd???
Hmmmm. Your video is already in mpeg2... I think iDVD only accepts Quicktime files. Automaticaly encodes and makes the dvd files, then burns them. Since you already have the video in mpeg2, the audio must be getting stomped in the conversion process. You can probably work ot a solution converting the file into a Quicktime move that iDVD will like, but it would be easier to just use Sizzle (it is like DVD Studio Lite, http://www.versiontracker.com/dyn/moreinfo/macosx/17331&vid=95199) to take you existing mpeg2 file and make the DVD.
converting from mpeg2 or wmv to a format for idvd or final cut express
By jbrown23 in forum ffmpegX general discussionReplies: 2Last Post: 8th Mar 2011, 22:23 -
burning hard subtitles into format to use in idvd?
By matteo121 in forum SubtitleReplies: 3Last Post: 28th Dec 2010, 18:44 -
I've got an animation I did in MPEG format and I want to burn it to a DVD
By el_cid in forum Newbie / General discussionsReplies: 6Last Post: 3rd May 2008, 15:11 -
Does iDVD make standard format DVDs (file structure-wise?)
By Scav2003 in forum MacReplies: 2Last Post: 5th Nov 2007, 02:11 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 07:00
