  1. how to capture video using dv/firewire using virtual dub
    is there anyother software we can capture using dv/firewire from digital camcorder
    thanks
    Apr 2002
    The State of Frustration
    DVIO can capture from firewire
    Hello.
    Dec 2002
    I use WinDV myself. It's more configurable and has more features than DVIO, and is still free. Scenalyzer Live is also a good capture tool, but is not free (it's fairly cheap though).
    Whatever you use, capture to Type 2 AVI and VirtualDub will be able to read the file. You will also need to install a DV codec, such as those available from Mainconcept or Canopus.
  4. thanks, i got windv, it is simple, but picture is not clear, picture is like have a water effect with waves, NOT CLEAR AT ALL... what to do? i tried capturing in adobe premier also same watery picture...?????
    and i am not sure about dv codecs, installed or not, can this bad pic be because of this?
    Apr 2002
    What happened with DVIO?
    Hello.
  6. DVIO webpage doesn't seem to open, if u have file i will appreciate if u can send it.
    what about the watery fuzzy picture, any ideas.
    plz help. very annoying....
    thnanks
