Tryin to use DVD2One to fit Back In The US onto one DVD-R. Got the file down to 4.3 Gigs but when I try to burn with Nero its telling me the file is to big. Using Datawrite 4.7Gb discs
what version of Nero, what type of disc are you burning (data, dvd-video, UDF 1.02, etc) and what steps are you taking to do it?
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Due to the confusing way that disc sizes are advertised, a "4.7"GB disc can store 4.3GB of data.
You're probably right on the DVD size limit cusp at 4.3GB. Try DVDShrink with the original source, it's end file size usually ends up slightly under the 4.3GB limit. -
I had the same problem with the default setting in DVD2one and burning with recordnow. Change the file size to 4450 in dvd2one and it should work
Hey,
I used to use Nero for everything...
It was a hassle and just gave me discs that were compliant on some standalones and not others (where they should be).
Just get the newest demo of CopyToDVD.
Great little program. The demo is full feature except for a little popup that reminds you to buy the prog.
Just my $.02 -
a 4.7 GB DVD actually holds 4.36 GB. I use DVD2One with a cap size of 4.472 GB. WOrks all the time.
max i can put on one is 4487 MB...and if you add in overhead..it amounts to a little under 4489 MB...which is 4.38 GB
https://www.videohelp.com/glossary#dvd-5
DVD-5 is a single sided single layer DVD that stores up to about 4 707 000 000 bytes and that is 4.38 GigaBytes where 1 kilobyte is 1024 bytes(4 707 000 000B / 1024 = about 4 596 679KB / 1024 = about 4489MB / 1024 = about 4.38GB) . Video DVD, DVD-R/W and DVD+R/W supports this format. Often referred to as "single sided, single layer".
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 06:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Burning Videos to DVD with Nero 9
By GeneYuss in forum Authoring (DVD)Replies: 6Last Post: 22nd Dec 2008, 08:11 -
Nero dvd burning, disabled?
By Remyisme in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2007, 14:55 -
Burning mpeg2 to DVD-9 with nero 6
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 04:11
