I was looking at the forum regarding a problem I had with the menu feature. i.e black screen (same as dave h. on June 18th). If I pressed play, first film played, and down + play second film played, but no menu picture.
As instucted I updated, now have version 1.0.1265.28718. Excited that this would rectify the prob, was somewhat disappointed when the same thing arose yet again when I tried another 2 films to one DVD,(tried both pal and NTSC to no avail).
any recommendations?
Thanx for an awesome piece of programming ChrissyBoy.
Much Respect
smig44Guest
Just spoke to CB on msn...I'm still having probs as well...
What DVD player have you got out of interest... I've got a "H & B DVD-5415S"
I'm getting the menu background + boxes...just no text in them...
i'm getting friends to test on theirs to see if there's any more they don't work on....
but big thanks.. to CB as it works on a few friends standalones..and they're well chuffed... i'm mega happy as well..as 90% of the menu works...and it doesn't take anything away from the superb converting from svcd2dvd achieved by this program! -
smig44Guest
I've got a Sony DVP-905V DVD player, don't even get a picture on this, just the sony intro screen, but still works with films fine by pressing play, or down play.
Same result on PC aswell, using WinDVD 4 on that... -
smig44: if you are having blanks on windvd then that is worrying. If you use say Badger #1 PAL, what size is the menu.mpg file left in there after you create a menu (no need to do the conversion - just "make Menu")?
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
Pinncle Studio v12: Menu appearing as blank green screen after render
By jbloggs in forum EditingReplies: 5Last Post: 6th Nov 2009, 22:06 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
blank asset menu
By anakin1312 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Apr 2008, 06:21 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
