hi i just captured a vhs tape to my hard drive using pinnacle studio deluxe 8.7, ive created all the menus etc. i am now at the authoring stage, i want to put it on dvdr first i tried burn directly to dvd-r after 3 hours of encoding a big error message popped up saying i had inserted incorrect media, i know for a fact its correct :/. Anyway i then chose the create disc content instead of burn directly to dvdr, it has now finished the process and i have ended up with these files (see screenshot) http://www.zen14331.zen.co.uk/Image1.jpg
now i do not know how to burn these files to dvdr to make one that will work in dvd players... wht do i do with these files??????????????/ plz i need help!!!!!
M2V files are the movies with no sound (I think)
the .wav files presumably the audio.
Your directory has a lot of those in and a lot of .wav files.
You'll need to load these into some kind of DVD authoring software.
I use DVD Maestro and it doesn't accept .wav files so you may need to convert the audio. -
DVD Maestro accepts wav files, PCM (wav) and AC3 are the supported audio formats under the DVD Standard.
With that said it looks like you encoded your captured video (from avi?) to MPEG. You have a series of m2v (video) and wav (audio) files. As mentioned above PCM audio is supported by the DVD standard, but as the audio is uncompressed the file sizes are rather large, you might have to convert them into ac3 files (compressed) to fit everything on one DVDR:
http://www.doom9.org/audio-guides.htm
What's also odd is that you said you made menus and set other DVD options, but the output is all unathored elementary streams. At any rate you'll need to author (see guides to left) those files to generate a VIDEO_TS folder with the necessary IFO/VOB files. -
ok yes i did capture to avi (8 gb file ) and then pinnacle converted it to those files u see it all come to 3.8gb enough to fit on my 4.7gb dvdrs, but since it means re encoding etc... ill just make the program re encode my movie straight to mpg , y didnt i do this originally? cause i wanted it to burn directly to disc :S thnx for ur help
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 07:22 -
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 13:42 -
join .m2v files?
By just in forum Newbie / General discussionsReplies: 5Last Post: 24th Nov 2008, 21:11 -
edit m2v files?
By SUPERIOR in forum EditingReplies: 2Last Post: 16th May 2008, 03:42 -
ts files into m2v or mpeg2
By vertical in forum Newbie / General discussionsReplies: 124Last Post: 21st Jun 2007, 14:12
