Hi
Trying to rip a DVDR using Smartripper, trouble is get a green screen in Smartripper, rips but DVD2AVI dont isn't happy to accept the files - HELP please
you should just be able to copy the files off the dvdr since it doesnt have any kind of protection..
you can try dvd decrypter.. www.dvddecrypter.com -
If you don't just want to copy the files, you can use DVD Decrypter.
All you would need to do is goto to the settings and uncheck all settings that would normally be needed such as remove protection and macrovision,etc. also the css key needs to be set to none. This is handy if you only want one secction (eg movie only) of a dvd-r. 8)
You don't know the power of the dark side!
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
