Hi all, I am new to capturing and have used VirtualVCR with a little success but because I am using a fat 32 drive I can't go over 4 gig in size and the only way to get a full movie while using a timer to capture is to drop the quality which I don't really want to do. I have heard that Virtualdub will split captures once the file gets to the 4 gig limit and I also hear there is a timer available. My question is when I first install virtualdub and click capture avi it works fine but when I go to use it again I get an error message saying the capture device is in use and will not allow me to select the capture drivers and then it says there are none. Now I know that nothing is running that uses my capture card unless there is a hidden programme so does anyone know what's going on ? Thanks in advance![]()
You have to set up capture drives in virtualdub first I believe. I'm not at my computer at the moment though.... Look under "capture"Originally Posted by solo
Hi, the 1st time I ran Virtualdub I did select my drivers, I am using Lifeview Flyvideo WDM video capture drivers but I checked out Virtualdubs web site and I just saw that it needs video for windows drivers and may not work with WDM drivers, maybe that's my problem ?
You may need what is called a "VFW/WDM wrapper." It used to be under tools, but I didn't see it a minute ago. Search your computer for vfwwdm32.dll, I think that's the name of it. Do a google search for it if you don't have it..Originally Posted by solo
I found it in my system32 folder, but i am not going to worry about it any longer because i found a great capture programme which works just fine, iuVCR found under capture in tools. So thanks to all those who helped
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 22:48 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
