Hi guys, total noob here would appreciate any help!
My computer: 17" PB w. SuperDrive
My DVD player: Pioneer DV-333
I took a movie from Divx to SVCD format using ffmpgx by using their handy dandy SVCD preset. I took the parts of the (mightily undocumented) output that looked like they matched what nearly incomprehensible tutorial on SVCD buring that came with vcdtoolsX described (a bunch of ordered .img files) droped it into Toast and burned me a nice disc.
Well the video quality came out much nicer than with VCD, but for some reason the aspect ratio is squashed flatter than it should be!
Any body seen this before or have some clue as to what might be causing it? Thanks for any help!
was the source letterbox and you had letterbox checked under the options? it is checked by default.
Square,
My source file is 512x384, the letterbox mark *is* checked but the source is not letterboxed. Also the output rez defaults to 480x480 for SVCD NTSC (which strikes me as strange but I have no idea what it should be so...)
Do I just need to uncheck the letterbox mark?!
autogk wrong aspect ratio
By codemaster in forum Video ConversionReplies: 8Last Post: 5th Feb 2011, 10:09 -
Wrong aspect ratio on TV: could 'Autoformat' cause it?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2010, 02:34 -
Wrong Aspect Ratio
By weathervane in forum Capturing and VCRReplies: 11Last Post: 18th Aug 2010, 23:18 -
Noob question - wrong aspect ratio
By contador in forum Newbie / General discussionsReplies: 8Last Post: 30th Jul 2010, 18:16 -
wrong aspect ratio ???
By clickit in forum ComputerReplies: 3Last Post: 7th Dec 2007, 03:49
