Results 1 to 11 of 11
    Feb 2003
    GREAT Britain
    Can anyone help me.I have just got a new 105 yesterday,installed it and burned about 7 dvd-r.When i later came to the drive Win XP did not recognise the 105 or my DVD-ROM?The 105 would not open the drawer whrn the button was pressed or do anything else.Anybody have any ideas?
    Same Dance,Different Disco!!
  2. open your computer and see if the power/ide cables are connected.. see if either drives show up in your bios.. try changing ide/power cables.. restart computer.. etc..
    Feb 2003
    GREAT Britain
    Thanks for the reply jeex.I have tried all that so much that i am convinced that the drive is dead.Nothing at all works on it and i have also fitted another 105 drive and it woks,cannot understand why i would be able to burn a few discs and then kapput.
    Dec 2002
    Dallas, TX
    Try switching to another power lead, switching the ide cable as well. If neither of those work then the drive is kapoot!! Hope you have the reciept...
    Feb 2003
    GREAT Britain
    I have installed another 105 on the same cable and chanel and it works!Thus bringing me to the conclusion it is the drive.
    Dec 2002
    Dallas, TX
    That really sucks. You can return it??
    Feb 2003
    GREAT Britain
    Oh YES!!Only had it one day!
    Dec 2002
    Dallas, TX
    had to ask, my friend throws out reciepts...
    Feb 2003
    GREAT Britain
    Could this be a record?the drive did'nt last 2hours
  10. What kind of motherboard are you running,chipset ? Are the jumpers set on the drives ?
    Feb 2003
    GREAT Britain
    Its a Biostar m7vib board and the jumpers on the writer were correct.As i said in previous posts i put another 105 in straight away and it works perfect
