Capturing at 720x480 MPEG2 with an ATI AIW 8500. I use TMPGE to filter and smooth. Never had no problems before, but now when TMPGE is done, it makes my new file extension as file and not mpeg. Before it would always make the file and mpeg extension not its just file. I manually went in and changed the extension to mpeg, and the file will play in WMP, but when I import the file into SpruceUp to author it says it is not compatable. Any suggestions??
Thanks Boxingjunkie![]()
Results 1 to 1 of 1
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
