I have Basically got a few svcd-which i would like to convert to DVD-R.
The program i realy want to use is cinema craft encoder version 2.5,i do also know that there is the svcd header/patcher trick but i would rather stick to the cce route. If some one could point me in the correct direction i would be very much appreciated as im a complete noob.
Thanks in Advance.
If you already have SVCD's why do you want to put them through CCE. You are not going to get better quality?
You can just use DVDlab and input your SVCD right from your CD as many as a DVD can hold.
http://www.mediachance.com/dvdlab/tutorial/svcd.html -
I appreciate what you are saying but its more of a compatibilty issue, thats why i would like to use cce. Thanks for youre reply.
Actually i just found something by Djrumpy in the advance conversion,he seems to know quite alot on the subject.
BD (AVC) to SD DVD NTSC with CCE
By stanley_a in forum Video ConversionReplies: 7Last Post: 28th Oct 2010, 13:04 -
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 10:10 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
DVD-RB with CCE taking 18 hours...
By hiimbored in forum DVD RippingReplies: 2Last Post: 23rd Nov 2008, 17:03 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 12:56
