I have downloaded a bunch of southparks off the internet (kaaza, bearshare) they are in avi's and mpegs. I have a nec dvd burner but its boxed by cendyne. I am currently trying to fit more than 4 videos on a stupid dvd. I am also trying to get around the transcoding..or at least the video part. I have currently messed around with vidomi,tmpeg,dvdx and also flask. Flask always seems to put the files out bigger than condensing them. vidomi takes ages to put mpeg into xvid. I am currently looking into trying to get them into m2v, of ifo's (which are sopposenly 4 rw).
I used tmpeg or whatever and shrunk the bitrate and the files did turn out smaller. but the audio was superfast (and cool). I am basically looking for a program easy to use. I am assuming i should probably get all the files in one format first.
what do you guys recommend
Results 1 to 1 of 1
DVD
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
help, newbie with a subtitle
By damien_omen in forum SubtitleReplies: 2Last Post: 20th Aug 2008, 07:30
