help guys, am still stuck with this one. I have a file that has mp3 audio and divx5 pro codec. Running it thro spot shows i have codecs installed, but when I run it thro tmpg the video freezes into a loop at the beginning, yet audio plays as normal.
I posted on this the other day and was told to increase directshow to 2/3. Well this is set on 5 but it still fails.
Have run video through Vdub for bad frames,, there are none.
Can anyone tell me what I am doing wrong? I only want to convert to svcd. I have also tried avi2svcd, but still it fails, why?
Many thanks for any advice people
Thanks Tom
I'm having a similar problem using Tmpeng 2.59 PLUs . I have a bunch of Divx movies I want to convert to either VCD or SCVD but Tmpeng will not open any DIVX files. I changed the Direct draw setting to +2 like the author above I have another program which converts the divx movies fine except it won't keep the 16:9 widescreen format so the VCd has a 'squished' look.
If someone can tell me how to get Divx to load into TMPENG TIA . Or another encoder which will convert and keep the 16:9 widescreen format intact . There must be a way to do this. -
Sorry should have stated that tmpg will encode the avi, but when it does encode the video is on a short 3 second loop at the beginning but sound works?
Could i be a corrupt codec?
Have also treid CCE but still no joy
Help Please! -
I solved my prob by upgrading my Tmpenc Plus 2.59 to the new Version 2.513.53.162 which just came out today. Now I can load the divx movies for conversion. Just started one now & hopefully it will work ok
AVI with DIVx or XVid codec?
By Sierraguy in forum Newbie / General discussionsReplies: 9Last Post: 8th Feb 2011, 10:47 -
WMV to AVI Using DIVX Codec Question
By TufrThanu in forum Video ConversionReplies: 8Last Post: 15th Nov 2008, 10:58 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 03:33 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 22:53 -
Configuring settings when converting to AVI (DivX codec)
By firas_hashim in forum Video ConversionReplies: 15Last Post: 24th Jun 2007, 02:21
