I have successfully transferred a DivX movie and added menus/chapters, etc onto DVD using NeroVision Express, however the picture quality is very "ordinary" with a lot of pixcelation (particularly when movement is involved). There is a lot of info out there on converting DVD to DivX but not much the other way round (ie: DivX to DVD). Am I expecting too much bearing in mind high compression with DivX or is there a better way of converting DivX to DVD? Or better still, is there a way of watching a DivX movie on a regular DVD player?
Any comments/help would be greatly appreciated.
You may want to framserve from Virtual Dub to TMPGEnc's DVD template and then burn that file.
Hello. -
huh...sorry im a layman....? framserve from Virtual Dub to TMPGEnc's DVD template ?... im a newb...clarify this please
What it does is have Virtual Dub open a video, where you can edit, add filters, etc. Then instead of saving it, your have TMPGEnc encode the video for you, using any TMPGEnc function as well. It is like running a video through two programs, but encoding it once. Click here.
Hello. -
That might not produce any better quaility thou (although TMPGenc is a much better encoder than Nero). The problem is garbage in, garbage out. You're DivX source is most likely of pretty poor quaility. Most DivX files then to be between 250-700MB with bitrates of 250kbit/s. Resolutions are normally 320x240 or there abouts.
Trying to convert that into a 720x480 8000kbit/s video will not improve the quaility. You can't improve the quaility about that of the poor source.
Generally speaking you should encode to a supported resolution at or just people your DivX resolution. But do not increase the resolution of your encode (that just doesn't work). -
Bit of a brain fart there vejita-samaOriginally Posted by Vejita-sama
. I think I know what you meant, below ?
try the new software Aare avi to vcd/dvd converter and merger, www.2shareit.com
ok...lets say i have a movie...looks good as a divx...Ive run it through my computer and watched it on the tele and its good...your saying i realy shouldnt bother selecting the 720x460 [?] when i encode it , its just a waist of time and wont look any better?
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
